Is there an errorlevel for the application?
We make backup with vaultmirror.exe too and it would be good when we can send emails if something wrong.
Regards Jakob
Solved by Redmond.D. Go to Solution.
No VaultMirror does not return an error code in failure cases. I can think of a couple of workarounds.
One option is to edit the source code to create your own version of VaultMirror that returns the error codes that you want.
Another option is to use the logging option. When Vault Mirror completes, scan the log to see if there was a problem. I think checking for the word "Error" will give you what you want.
