Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Errorlevel for VaultMirror.exe?
2 REPLIES 2
anandax
339 Views, 2 Replies
Is there an errorlevel for the application?
We make backup with vaultmirror.exe too and it would be good when we can send emails if something wrong.
Regards Jakob
2 REPLIES 2
Redmond.D
in reply to: anandax
No VaultMirror does not return an error code in failure cases.  I can think of a couple of workarounds.
One option is to edit the source code to create your own version of VaultMirror that returns the error codes that you want.
Another option is to use the logging option.  When Vault Mirror completes, scan the log to see if there was a problem.  I think checking for the word "Error" will give you what you want.
Doug Redmond
Software Engineer
anandax
in reply to: Redmond.D
Thank you for the answer. I will try to edit the sorce code.
