Greetings.
While performing a Copy Design on a drawing, the attached error message was displayed. Does anyone have an idea what it means or what the problem might be? Any ideas about what I should be checking re: settings etc?
Inventor 2012 Pro and Vault 2012.
Thanks in advance,
Steve
Can you try this and see if that helps?
1. Open the IDW inside Inventor
2. Check out, Save and Check-in with DWF
Now try Copy Design. If this doesn't help you may need to share the IDW and IPT files to me so that I can give a try. You can send it to me at senthilDOTkumarATautodeskDOTcom
Thanks for your response. I'll give it a try and report back.
Steve
