i have a problem with one Workstation: If i want to copy, rename or move an Inventor file, i get the error message "Falscher Parameter." (in englisch wrong parameter).
The other workstations dont have this problem.
The System:
Windows7 x64 without SP1
Vault Workgroup 2011
german
What i have tested:
- deinstall and install new the Vault client with servicepacks and hotfixes
- deinstall and install the DotNet-Framework v4 and v3.5.1
- log-in as an other user
=> nothing was successful
Has anybody an idea or a solution?
Thanks!
Best regards
Michael
Solved by Senthil_Kumar. Go to Solution.
Could you please check the following to see if they help you solve the issue with Move / Rename?
> Ensure you have Vault 2011 SP2 is installed
> Ensure C:\Temp is NOT Readonly
> Ensure Inventor Project Shortcut folder is NOT Readonly. Usually %UserProfile%\My Documents\Inventor
Thanks for your answer.
But i'm sorry. This morning i load back the backup-image. I had no choice because i have to work with it.
To your questions:
- Yes, Vault SP2 was installed.
- Yes i think that i had the right permissions to c:\Temp and the profile.
Thanks for your update.
Do you still see the error with Move and Rename commands?
If that is the case I would recommend you to log a Support Request and someone from the Support team will help you.
I am sorry that I am not able to help you much here.
this was the solution. Thanks.
We had this problem, too: http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2011-not-loading-project-file/td-p/2709075
So my autodesk-dealer talked to me to set the project shortcut read-only. But first i don't remembered to this.
Michael
Thanks for the update and glad to know that the issue is resolved.
