Vault General Discussion
*Expert Elite*
Dan.M
Message 1 of 5 (152 Views)
Error during check in
152 Views, 4 Replies
10-11-2009 07:10 AM
Hello All ,
During check in I got the following error . pic attached .
Anyone has a solution ?
Active Contributor
jorgen_bjornes
Message 2 of 5 (152 Views)
Re: Error during check in
10-11-2009 08:33 AM in reply to: Dan.M
I've had similar problems. The problem was primarily with checking in imported geometry.
Installing the TS1093427 hotfix fixed the issue.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12268454&linkID=9242499
Make sure you do a proper backup and follow the instructions carefully.
*Expert Elite*
Dan.M
Message 3 of 5 (152 Views)
10-11-2009 11:24 AM in reply to: Dan.M
What do you mean when you say " imported geometry " ? DWG files are imported geometry ?
Dan
Active Contributor
jorgen_bjornes
Message 4 of 5 (152 Views)
10-11-2009 12:11 PM in reply to: Dan.M
With imported geometry I mean that I had problems with SOME components that were imported from Step, sat etc.
3D DWG geometry is also non-inventor geometry, but I cannot say if dwg-geometry might cause this. I have mainly worked with imported STEP, not dwg.
*Expert Elite*
Dan.M
Message 5 of 5 (152 Views)
10-13-2009 02:21 PM in reply to: Dan.M
I thinks that this error is coming from database itself. I tryed some maintenance scipts but nothing helped . The thing is that I can work normally for a few hours and suddenly everything is working very vey slowly and i get the error . Also when I am pointing on a folder inside the PS it takes 10 minutes maybe more to populate . I am thinking to do a reinstall of the entyre system .
Dan
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
