Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error during check in
4 REPLIES 4
Dan_Margulius
279 Views, 4 Replies
Hello All ,
During check in I got the following error . pic attached .
Anyone has a solution ?
4 REPLIES 4
in reply to: Dan_Margulius
I've had similar problems. The problem was primarily with checking in imported geometry.
Installing the TS1093427 hotfix fixed the issue.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12268454&linkID=9242499
Make sure you do a proper backup and follow the instructions carefully.
What do you mean when you say " imported geometry " ? DWG files are imported geometry ?
Dan
With imported geometry I mean that I had problems with SOME components that were imported from Step, sat etc.
3D DWG geometry is also non-inventor geometry, but I cannot say if dwg-geometry might cause this. I have mainly worked with imported STEP, not dwg.
I thinks that this error is coming from database itself. I tryed some maintenance scipts but nothing helped . The thing is that I can work normally for a few hours and suddenly everything is working very vey slowly and i get the error . Also when I am pointing on a folder inside the PS it takes 10 minutes maybe more to populate . I am thinking to do a reinstall of the entyre system .
Dan
