Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error 303 "No permission" on purge
2 REPLIES 2
miechh
1426 Views, 2 Replies
In december we migrated from Vault 2012 to 2014, until then the purge-command worked. This morning I wanted to purge some documents from the Vault (Basic 2014). My account in Vault is one with administrator rights, but it still didn't work. I then checked the permissions in the Global Settings in Vault and concluded that the Purge-command should be available to me. Tried purging again, but still Error 303. Then I logged in as Administrator and tried it again, same error.
I stumbled on a message of someone else here, with the same problem.
What's wrong here? Help is greatly appreciated.
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
2 REPLIES 2
Senthil_Kumar
in reply to: miechh
Can you please refer this help for more info on how to enable the purge and also for information related to Purge?
http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-36F79FDE-C4C3-453A-B687-127741AADD5B
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
miechh
in reply to: Senthil_Kumar
That's it! Checked the file references of the to purge documents and enabled purge on the Vault Server via ADMS. Thanks a lot!
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
