Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error 29001: Vault management error: 114 on new VW 2014 Server
4 REPLIES 4
MattiasLanzen
1270 Views, 4 Replies
I get the error describe in the subject....
The pre-check works great and everything in the installation work fine until it’s time to install language pack.
Get this error:
Log file:
Autodesk vault workgroup 2014 (server) language pack failed installation aborted result=1603
I have tried:
Uninstall all .net versions and let the installation install
Uninstalled IIS and let the installation install it
Checked so IIS application pool is running .net 4
Environment:
Windows Server 2008 R2 SP1
MS SQL 2012 SP1
Completely new installed server and its dedicated to just run Vault. So no other running services/program on the server
No other antivirus then windows own
4 REPLIES 4
paul.gunn
in reply to: MattiasLanzen
114 indicates that there was an error creating the server databases. There should be more details the server vlog - these are located at C:\ProgramData\Autodesk\VaultServer\FileStore
Paul
MattiasLanzen
in reply to: paul.gunn
Yes you are right, i get this error in the log-files..
"Exception(Inner): The CREATE DATABASE statement failed. The primary file must be at least 50 MB to accommodate a copy of the model database."
The solution for this error is really simple.
Problem: The Model databas is to big
Solution: RMB on Model database, Tasks --> Shrink --> Database
For more info about Shrinking the database: http://technet.microsoft.com/en-us/library/ms189035.aspx
paul.gunn
Glad to hear you found the solution Mattias.
That error was a new one for me!
Paul
