I get the error describe in the subject....
The pre-check works great and everything in the installation work fine until it’s time to install language pack.
Get this error:
Error 29001: Vault management error: 114
Log file:
Autodesk vault workgroup 2014 (server) language pack failed installation aborted result=1603
I have tried:
Uninstall all .net versions and let the installation install
Uninstalled IIS and let the installation install it
Checked so IIS application pool is running .net 4
Environment:
Windows Server 2008 R2 SP1
MS SQL 2012 SP1
Completely new installed server and its dedicated to just run Vault. So no other running services/program on the server
No other antivirus then windows own
Solved by MattiasLanzen. Go to Solution.
Solved by paul.gunn. Go to Solution.
114 indicates that there was an error creating the server databases. There should be more details the server vlog - these are located at C:\ProgramData\Autodesk\VaultServer\FileStore
Paul
Yes you are right, i get this error in the log-files..
"Exception(Inner): The CREATE DATABASE statement failed. The primary file must be at least 50 MB to accommodate a copy of the model database."
The solution for this error is really simple.
Problem: The Model databas is to big
Solution: RMB on Model database, Tasks --> Shrink --> Database
For more info about Shrinking the database: http://technet.microsoft.com/en-us/library/ms189035.aspx
Glad to hear you found the solution Mattias.
That error was a new one for me!
Paul
