Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error 1455
64 REPLIES 64
Message 1 of 65
avaya2012
5707 Views, 64 Replies
Error 1455
I recently checked a couple small assemblies into Vault from Inventor 2013 from one computer then came to mine and checked it out to do my thing.  I then created a drawing and checked both back into Vault.  Everything seemed to be working fine until I tried to Assign Item to the assembly in Vault.  I get Error 1455 which reads:  The file was added in a way that did not include the correct item data.
What did I do wrong?
What can I do to fix this issue?
64 REPLIES 64
Message 61 of 65
gavbath
in reply to: KooCheeKit
This helped me thanks. I was performing a check-in through the API, and had the option to upload BOM data set to false, which was causing this error. Your comment helped me to figure that out, so thanks.
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
Message 62 of 65
ktucker
Glad I could help.
Cheers
Kevin Tucker
Section Head (Drawing Office)
Engineering Department
Welfit Oddy
Work: +27 041 4046715
Cell: +27 0829409891
Fax: +27 0865284776
Email: ktucker@oddy.co.za
Message 63 of 65
dcoulam3
in reply to: avaya2012
I have typically been able to overcome this error by removing the offending file from the item and adding it back to the same item.
To do this, you edit the item, right-click on a file, first choose Go to Folder (this happens in the background), right-click again and select Remove Link, Save & Close the Item.  The folder you brought up before will be the active window.  You can select the file you just removed from the item and pick Assign Item again.  Click next on the first screen, and right-click in the Replace With column.  Click Select Replacement Item and choose (check) the item originally assigned.  Once it is back in the Item, you can verify the success by running Update
Sometimes, the most difficult part is finding which file is the problem.  It would be nice if the error specified which "file was added in a way...".
Message 64 of 65
john_j_garcia
in reply to: PACDrafting
If anyone happens to still have this issue too, I had this one for quite some time and after a lot of time spent on it, it is 100% files checked out below the item in question.  The easiest way to fix is to look in the uses tab, add column "checked in" expand all, and review the entire list (unfortunately).  Files that are checked out have a blank date field.
Message 65 of 65
Experienced this in Vault Professional 2021.
User wanted to perform "Assign/Update Item" on a complex Inventor Assembly for initial release and got this error.
This IAM contained multiple parts, of which some were designed before Vault was introduced in our company. It is suspected that something went wrong during migration of one or more of the IPTs used in the IAM, resulting in a "NaN" value in the Density -iProperty of some IPT.
We fixed this by:
  1. Check out the IAM and all of it's children
  2. In the Manage -tab, hit Rebuild All
  3. Try to check-in the IAM and all of it's children
  4. If you get errors during this procedure: go to the faulty files and check its iProperties for "NaN" values where Vault might expect integers
  5. Try to check in all the child-files
  6. This should solve the issue.
(Admin rights might be useful to perform these steps)
Toon Broothaerts
If my answer solved your question, please mark it as 'solution'. Else, feel free to contact me!
