Good Afternoon,
I'm working on Autodesk Vault API, and I'd like to know if it was possible to display a Data Card (as they are available since 2011) in a stand alone way via the API (pop-up for example).
I guess not, from the fact that the API is server sided, but I would like to have a confirmation that this feature isn't available and that isn't any existing workaround.
Thanks for your help,
Hello Nicolas,
You might want to move this thread over to the Autodesk Vault Customization forum. Hopefully the link below will work for you:
http://forums.autodesk.com/t5/Autodesk-Vault-Customization/bd-p/301
-Jim
Hello Jim,
I'd moved the thread to the good section.
New url :http://forums.autodesk.com/t5/Autodesk-Vault-Customization/Display-Data-Card-from-API/td-p/3661830
