Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Delete Item in Productstream 2009 from SQL Enterprise
2 REPLIES 2
lbarragan
221 Views, 2 Replies
I need to know how I delete an item of engineering within the SQL SERVER Database. What are the forms within the database to completely delete an item?, Since the normal procedure to remove an item of engineering did not work, need to know how this can be done from the SQL SERVER Database.
STEPS ARE NEEDED TO MAKE THIS PROCESS.
Thank You.
Leandro Castellanos
GRAPHO Design Software - Brazil
2 REPLIES 2
in reply to: lbarragan
Sorry, but we don't support direct modifications to the databases via SQL as
doing so could break the applications in subtle or not so subtle ways.
I recommend that you either open a call with Product Support (either thru
your reseller, or thru your subscription, whichever applies); or post some
specifics about what is preventing you from doing this from the Vault
Manufacturing client such as the errors you are seeing, etc. I assume some
restrictions are preventing the deletion?
Dave Mink
Autodesk / Data Management
If you need to remove an Item in Productstream, the recommended way is to
make the Item Obsolete, then you can delete it. Hope this helps.
Brian Schanen | Customer Success Engineer | Data Management
-----Original Message-----
Posted At: Friday, October 16, 2009 11:59
Posted To: autodesk.productstream
Conversation: Delete Item in Productstream 2009 from SQL Enterprise
Subject: Delete Item in Productstream 2009 from SQL Enterprise
Thank You.
Leandro Castellanos
