Hi, ran into something weird this morning in Vault Pro 2013. I created a custom property and mapped it to pick up the value of a system property. I was pulling my hair out trying to figure out what was wrong with my mapping as it would not show the property no matter what I did. UNTIL... I manually edited the properties and entered a string of garbage in the custom property. Then did a Sync Properties. The property I had just entered as garbage suddenly did what it was supposed to do and took the value of the property it was mapped to. This happened twice with two different custom props.
UPDATE:
Same thing happened when I assigned an Item from this file. I had to manually enter a value in this property before Update would work and bring in the value of the property from the file.
Has anyone else run into this? Basically, Prop Sync on a custom property mapped to a Standrad property will not work unless a value is first manually assigned to it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
