Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Create new property for a File in autodesk Vault 2012 in VB.net
6 REPLIES 6
sabuj.saha
841 Views, 6 Replies
I am wanting to create a new property for a file in vault. I could not find any code sample to start with.
Any idea how can I do it...
6 REPLIES 6
FarrenYoung
in reply to: sabuj.saha
Hi Sabuj,
You will likely get more results in the Vault Customization forum.  You are in the general forum.
http://forums.autodesk.com/t5/Autodesk-Vault-Customization/bd-p/301
Have you seen the AddPropertyDefinition function on the PropertyService class?
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
FarrenYoung
I found the following via www.google.com
http://adndevblog.typepad.com/manufacturing/2012/06/add-user-defined-property-by-vault-api.html
--Farren
sabuj.saha
in reply to: FarrenYoung
I found that after I posted this thread...
Thanks For the link...
sabuj.saha
The property mapping in that example is write.. I am needing a property that will do both ways.
Do you know how that can be done?
Regards
Sabuj
FarrenYoung
Do you have the vault api help file?  You should be able to search that and see:
AllowedMappingDirection Enum
Summary
The allowed property mapping direction values.
ValuesNone
Read
ReadAndWrite
Write
Also, if you use Visual Studio you should have intellisense that would show you the options...
--Farren
sabuj.saha
Thanks you so much..I will try that and get back to you on that....
