The allowed property mapping direction values.
ValuesNone
Read
ReadAndWrite
Write
I am wanting to create a new property for a file in vault. I could not find any code sample to start with.
Any idea how can I do it...
Hi Sabuj,
You will likely get more results in the Vault Customization forum. You are in the general forum.
http://forums.autodesk.com/t5/Autodesk-Vault-Customization/bd-p/301
Have you seen the AddPropertyDefinition function on the PropertyService class?
I found the following via www.google.com
http://adndevblog.typepad.com/manufacturing/2012/06/add-user-defined-property-by-vault-api.html
The property mapping in that example is write.. I am needing a property that will do both ways.
Do you know how that can be done?
Regards
Sabuj
Do you have the vault api help file? You should be able to search that and see:
AllowedMappingDirection Enum
