Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Could Vault Basic and Professional coexist?
5 REPLIES 5
luis_andueza
480 Views, 5 Replies
Hi everyone,
I am new in the Vault World,
Could I have installed Vault Basic and Vault Professional on the same server? and what about the clients? Could they have installed Vault Basic and Professional at the same time?
Thank you.
Luis José Andueza Castro
Ing. Mecánico - Consultor CAD/CAM/CAE/Data Management
www.dimcad3d.com | LinkedIn |
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Entonces haz clic en el botón ACEPTAR SOLUCIÓN.
5 REPLIES 5
DarrenP
in reply to: luis_andueza
you can't install 2 vault servers on one machine
you have to choose
DarrenP
DarrenP
in reply to: DarrenP
unless you are running a vm on one of the servers
then you can install one of them on the VM and the other on the actual server
DarrenP
luis_andueza
How About two Vaults on the clients side? Can I have two vaults so I can enter in a basic server for some projects and to a professional server for other projects?
DarrenP
you should able be to install both clients on 1 machine
DarrenP
michael_berger
I've installed Vault Basic and Professional 2017 on the same client (Professional for use in company and basic @home)
now, when i start inventor 2017 there is the login-windows - after choosing server entering my login data there is an error "Die bezogene Lizenz ist nicht mit dem Server kompatibel" (like " the gotten licence is not compatible with server")
i guess the inventor 2017 plugin is the basic and this wont work with the professional server...
so is it possible to change the plugin-edition while using inventor?
thanks
p.s.:
when i just open the application for it's own i can access the professional server with the professional client and the basic server with the basic client... no problems... just the inventor got problems...
