Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Copy Design Failing - Error Repairing WDP file
1 REPLY 1
drathak
230 Views, 1 Reply
I'm trying to make a copy of my design in Vault (AutoCAD Electrical 2013 & Vault Pro 2013) and I am getting this error which ends the process.
Any ideas what is causing this or how I should procede?  This is the first indication I've seen that the WDP file needs repairing.  Or is it telling me it can't repair the new copy?  (Version 2)  If so, what exactly is this telling me?  (See attached image.)
Thanks.
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
1 REPLY 1
cbenner
in reply to: drathak
Autocad Electrical designs should be copied using the Electrical application.  Not Vault.  You can Copy Design right inside of Electrical, and then check it into Vault.  The Copy Design feature is very handy, it allows you to decide which drawings in a project you want to copy, or all of them... and also lets you rename them and point to a new location.  Look it up in Autocad Electrical under the Project tab.
