Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Column for showing the folder
4 REPLIES 4
katterbauer
316 Views, 4 Replies
is there a column (setting) to show the folder of a file?
The use case would be to perform a search across many folders and subfolders that brings up a result of many files. In this search result i want to see the folder name (or workspace path) for each found file. I did not see a column matching this information.
Is there a setting/column for this?
In case needed, I use Vault Collaboration 2011.
Thx,
klaus
4 REPLIES 4
alan_ho
in reply to: katterbauer
Hi Klaus,
You can customize the main grid to include the 'Path' field.
This will allow you to view the folder location in the vault.
Alan Ho
Principal Experience Designer
Digital Platform & Experience
Autodesk, Inc.
katterbauer
in reply to: alan_ho
Hi Alan,
thank you for the quick response, but I can´t find a field called "path" in the available columns if i choose to expand my view of the grid (I right click the columns in the grid and use the command for customizing the view).
I think it should make no difference that i use the german version of vault collaboration 2011? (i searched for other columns that could be translated for "path" but still no match).
klaus
alan_ho
Klaus,
My apologies for I missed out your environment.
The 'Path' field is only available in Vault 2012.
The 'Path' or 'Folder' field cannot be displayed in 2011 out of the box.
Alan Ho
Autodesk, Inc.
katterbauer
OK, one more reason to update Smiley Happy
