Environment:
Win 2003
Vault 2013 + SDK
Visual Studio 2008
I add the SDK \bin\ path to reference paths.
When trying to compile the VaultMirror that comes with the SDK, but I get this errors:
Warning 1 The referenced component 'Autodesk.Connectivity.Explorer.Extensibility' could not be found.
Warning 2 The referenced component 'Autodesk.Connectivity.Explorer.ExtensibilityTools' could not be found.
Warning 3 The referenced component 'Autodesk.Connectivity.Extensibility.Framework' could not be found.
Warning 4 The referenced component 'Autodesk.Connectivity.JobProcessor.Extensibility' could not be found.
Warning 5 The referenced component 'Autodesk.Connectivity.WebServices' could not be found.
Warning 6 The referenced component 'Autodesk.Connectivity.WebServices.XmlSerializers' could not be found.
Error 7 The type or namespace name 'Autodesk' could not be found (are you missing a using directive or an assembly reference?) C:\Program Files\Autodesk\Autodesk Vault 2013 SDK\VS10\CSharp\VaultMirror\FullMirrorCommand.cs 16 7 VaultMirror
Error 8 The type or namespace name 'Folder' could not be found (are you missing a using directive or an assembly reference?) C:\Program Files\Autodesk\Autodesk Vault 2013 SDK\VS10\CSharp\VaultMirror\FullMirrorCommand.cs 38 13 VaultMirror
Error 9 The type or namespace name 'Autodesk' could not be found (are you missing a using directive or an assembly reference?) C:\Program Files\Autodesk\Autodesk Vault 2013 SDK\VS10\CSharp\VaultMirror\FullMirrorCommand.cs 17 14 VaultMirror
Error 10 The type or namespace name 'Folder' could not be found (are you missing a using directive or an assembly reference?) C:\Program Files\Autodesk\Autodesk Vault 2013 SDK\VS10\CSharp\VaultMirror\FullMirrorCommand.cs 78 13 VaultMirror
Error 11 The type or namespace name 'Folder' could not be found (are you missing a using directive or an assembly reference?) C:\Program Files\Autodesk\Autodesk Vault 2013 SDK\VS10\CSharp\VaultMirror\FullMirrorCommand.cs 81 26 VaultMirror
Error 12 The type or namespace name 'Folder' could not be found (are you missing a using directive or an assembly reference?) C:\Program Files\Autodesk\Autodesk Vault 2013 SDK\VS10\CSharp\VaultMirror\FullMirrorCommand.cs 132 21 VaultMirror
Solved by Redmond.D. Go to Solution.
The Vault DLLs have moved to .NET 4.0, which requires Visual Studio 2010 or later.
See the following article for more information: http://justonesandzeros.typepad.com/blog/2012/05/net-4.html
