After un-installing vault prof client 2013, due to some problems, it is not possible to re-install this again.
The setup say's that it is already installed.
Have someone a solution to solves this.
Solved by Ad.Aarsman. Go to Solution.
Solved by david.lau. Go to Solution.
Solved by r.smith1. Go to Solution.
What method did you use to uninstall the client?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I used the standard windows uninstall, but this one did run into a error. So I had to break of the uninstall.
Then I used Revo uninstaller Pro to uninstall. The link disaperaed from my desktop and also the program directories where removed and a lot of registeries.
Hopefully you can help.
Have you since gone back into Control Panel to see if it is gone from there? If the uninstall failed, there are probably registry entries that are still intact that make it appear as if the program is still there.
Chris Benner
Hi Ad.Aarsman
Please try to use the Microsoft FixIt utility to remove the remainder of the application that is still loaded on your workstation.
I tried Fix-it but the program is asking for a product code, which I don't know.
(Program was not listed)
Can you help me with the product code, it is something like the attachment.
Thanks in advance.
Chris,
it is gone from the Control Panel.
I'am now trying Fix-it.
Maybe I am coming back to you when this is not working.
Ad Aarsman
Hallo,
I did found the key (product code) in a log file and with this key the fixit tool did uninstall the vault program.
Only when I install it again it starts installing but gives the following error:
Installation complete. Some product failed to install.
See attached installation log file.
Maybe you can do something with this log file.
Ad
Check out this post:
http://upandready.typepad.com/up_and_ready/2012/06/windows-the-basics-of-using-microsoft-fix-it.html
I have used this a lot and it has worked flawlessly. Don't bother with Revo (trial) etc. 🙂
Hallo David and Chris,
After several tries with Fix-it and with the correct product code it succeded finaly.
Thanks for your help.
