Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Can't "Open from Vault" my Inventor assembly
7 REPLIES 7
Message 1 of 8
karthur1
830 Views, 7 Replies
See the video below.  When I do an "Open" from Vault explorer and say "No" to the "do you want to overwrite" the local file" question, It just stops and does not open the iam.  If I say "Yes" to this question, it will open.
I want to open it but not overwrite the exisiting file on my local workspace.  I can go to Inventor and it opens fine with the out of date file.
Why is that?  Seems to be a bug of some sort.
Here is the video.http://screencast.com/t/JlXPXVoqltU
Here is a video if I say "Yes" to the question.  NOT what I want, but just to show that it will open from Vault.  http://screencast.com/t/MiXDZ5xCc7
Kirk
7 REPLIES 7
Message 2 of 8
herrerh
in reply to: karthur1
Kirk,
Try your workflow again if you are planning to install Subscription Update 1.  The way we work with Edited out of turn files has changed.
I was able to duplicate your workflow and what you saw before the update.  Now, after the update Inventor will always open after.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 8
karthur1
in reply to: herrerh
Hywell,
I updated the vault 2014 server and client to update 1.  It did not change anything, it still does not open if I select "No" to not overwrite the file.
Kirk
Message 4 of 8
herrerh
What builder number is listed in help -> about in ADMS Console and the client?
-Hywell
Hywell Herrero
Product Support
Autodesk, Inc.
Message 5 of 8
karthur1
Bother server and Client says build 18.1.8.0 (Update 1)
Message 6 of 8
herrerh
Thats what I thought.  The Update 1 that you will want to install is Subscription Update 1, which is available in the Subscription Center.
-Hywell
Hywell Herrero
Product Support
Autodesk, Inc.
Message 7 of 8
karthur1
Thought that I had update 1....what I actually have is Service Pack 1, hotfix 1.
What I need is Service Pack 1, Hotfix 2. I see that on the sub site now.
Why don't they just issue Service Pack 1, then Service Pack , and so on.......etc. Would make it less confusing I guess.
I will give that a shot and report back.
Message 8 of 8
herrerh
At the end of everything, you should have a build number of 18.100.12.0.
Hywell Herrero
Product Support
Autodesk, Inc.
