Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Autodesk Vault Collaboration 2011 File Replication
4 REPLIES 4
m.sabotto
439 Views, 4 Replies
I'm checking the status of the File Replication between two workgroups.
From the Console I see that there are 960 files (~101 MB) unreplicated.
Just to be sure I searched (on both workgroups) for all files with the "File Replicated" property = False.
Found only 2 matches(!!!???).
My question is: where "960 unreplicated files" information come from?
Which is the best way to check if all files have been replicated?
Thank you in Advance
Max
4 REPLIES 4
paul.gunn
in reply to: m.sabotto
paul.gunn
By default a search will only include the 'latest' versions of a file. You might want to retry you search with 'latest' unchecked - this may resolve the discrepency you are seeing.
Paul
MSabottoAdskID
in reply to: paul.gunn
HI Paul,
thank you for the feedback, but did not solved the issue.
I still get only few files with the "File Replicated" property set to false, but the console still display 260 unreplicated files.
Do you know where that information camo from? I mean a Stored Procedure or something else?
Max
paul.gunn
in reply to: MSabottoAdskID
Hi Max,
It is puzzling that you are seeing this discrepency. Ultimately both data come from the database - though the search information is served through an index. You could try rebuilding the search index in ADMS console - in case that somehow the search index has gotten out-of-date. Failing that however, I would advise contacting product support with this issue - to my knowledge this is not a known problem.
Paul
