I intend to use a 4 year old server with a 32-bit processor with Server 2008 Standard installed to run our Vault 2014 Server. Because R2 requires 64-bit I can't install it on the server, but it is listed as a system requirement for Vault 2014. Is anyone else running Server 2008 Standard 32-bit successfully with Vault 2014?
Solved by mdellunto. Go to Solution.
Hi AnnetteMcLaughl,
I am not sure where you read Vault 2014 needs a 64bit server. You should beable to install a 32bit version of Vault 2014 on a windows server 2008 standard (32bit). Please review the link below.
For 32-bit Autodesk Data Management Server 2014
Hope this helps 😄
Cheers!
I understand what your saying now it does say Windows 2008 Server Standard or Enterprise edition (SP2)
I have only install vault on a 64bit server. 😞 Maybe someone else can share the reviews with a 2008 standard.
I can say if you have a large database or filestore then you may want to use a 64 bit server for preformace but other then that I can't say how well 2008 std would work.
I had a windows 2003 standard server running Vault 2009 a while back and it worked fine I would say that 2008 standard would be the same.
Good Luck!
Annette,
could you post a screenshot and the log file from %TEMP% so we could review.
Perhaps it is complaining about SQL Server not having SP3?
From what I understand you can install SP2 on a server 2008 Standard 32bit on a server that only supports 32bit hardware. You should be able to download SP2 for windows server 2008 standard from the link below.
http://support.microsoft.com/kb/968849
You should beable to install it regardless if the system is 64bit supported. Do you not get the update VIA windows updates?
You will see in the link that SP2 applys to Standard
Article ID: 968849 - Last Review: February 3, 2011 - Revision: 2.1
APPLIES TO
Windows Server 2008 Standard
Windows Server 2008 Enterprise
Windows Server 2008 Datacenter
Windows Server 2008 for Itanium-Based Systems
Windows Server 2008 Standard without Hyper-V
Windows Server 2008 Enterprise without Hyper-V
Windows Server 2008 Datacenter without Hyper-V
Windows Server 2008 Service Pack 2
