I have recently installed Autodesk Vault 2013 (client) onto our server ( Vault server).
The server is configured to IPv4 and firewall is switched off.
We are receiving an error (319 in server logs) when trying to aquire a license to run the Vault client.
11/12/2012 11:52:03 *******************************************************************
Error: Soap Exception ( mesg-id = 634908235237587890 )
Exception: LicensingError [319] (20)
Stacktrace:
Server stack trace:
at Connectivity.Core.Security.Licensing.LicenseCheckOut(User user, ProductLicenseType productType)
at Connectivity.Core.Services.SecurityService.CreateLicensedToken(User user, String knowledgeVaultName, Boolean readOnly, ProductLicenseType licType, Byte[] p)
at Connectivity.Core.Services.SecurityService.SignIn(String userName, String userPassword, String knowledgeVaultName, Boolean readOnly)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Web.Services.v17.SecurityService.SignIn(String userName, String userPassword, String knowledgeVault)
Any ideas?
Thanks in advance.
Billy
Have you verified that your lisense service is running? In our case it was being automatically shut off on the server once a month when the server ran automatic Windows updates. I had to go to the server and manually restart the lisense service. Last month I shut off the auto updates on the server,... crossing my fingers that this solved the problem.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for your reply.
We already have one Vault server picking up the license from the same license server working ok.
For some reason this second server is not.. The services can not be the issue.
Anything else I could try?
Billy Chan
Sounds like you are using replication? Unfortunately I am not too well versed in replication issues. I'm going to bump this for some other guru to look at.
Chris Benner
We're not using replication. We have two different sites set up.
Both sites should point to the same license server based on the LICPATH.LIC file.
Connecting to site A is fine, but using the same machine connecting to site B is failing to obtain the license... even though it is pointing to the same license server.
Billy Chan
Has this worked before and just became a problem, or is it a new issue?
Chris Benner
This is a new issue, performed a new install on a new VM (virtual machine).
Bit of a strange one..
Billy
On the server that is having trouble getting licenses, open a command shell and ping the license manager hostname. You may find that the hostname is being resolved to an IPv6 address instead of an IPv4 address. If that is the case you can either switch to the IPv6 license manager (which would require all access to be via IPv6), fix the name resolution so you get an IPv4 address, or use the IPv4 address instead of the hostname in the server's LICPATH.lic file.
-Dave
Hi Dave,
Thanks for your reply. I can confirm that pinging our license server it is resolving in IPv4 format.
Please see attachment.
Billy
what about the firewall?
allow these ports:
The FLEXlm® based version uses the following ports:
DarrenP
are all machines not picking up a license or just certain ones?
DarrenP
Good news, I noticed there were a TCP and UDP rule set up for inbound and outbound connections. I disabled this then restarted the server. Appears to be picking up the connections fine now.
Although a new error has now occured for Active Directory accounts trying to connect.
I have tried the solution here http://crackingthevault.typepad.com/crackingthevault/2009/12/windows-authentication-not-working.html... by enabling windows authentication. No luck.
Billy
Billy,
For WinAuth, ensure that only the Windows Authentication Auth type is enabled for \Default Web Site\AutodeskDM\Services\WinAuth inside IIS.
I believe the prodivders should be Negotiate and NTLM.
Hope that helps.
-Andy
That is great, it is now working.
Just a FYI, I had to perform that solution on the AutodeskDM>services home > Authorisation as well to make it work.
Thank you very much.
regards,
Billy Chan
