Group,
Many of you have seen the video on youtube re: Vault 2012 & '13 Integration into Sharepoint 2010 - it's pretty slick, you can access Vault Professional 2012 & '13 from within Sharepoint 2010. Vault 2012 & '13 & Sharepoint 2010 Integration on Youtube
I have tried to set this up for demo purposes & am not seeing the same options as listed in the instructions for the integration. Vault Pro 2013 Integration instructions for Sharepoint 2010
I've confirmed you only need Sharepoint 2010 Standard & higher for this integration.
Even going up to Sharepoint Enterprise, I don't have "federated search" & a number of other options listed in the screenshots from the Autodesk tutorial. I've found some microsoft TIDs concerning federated search, will update this thread when I get it dialed in.
If anyone has already done this & has tips for the group please post to this thread.
Thank you,
Can you contact me to help you out?
I believe that you have missed a configuration setting outlined in the document.
Irvin,
Nice to see you are still around. I missed several configuration settings actually. Did not notice the 35pg PDF extracted to the sharepoint server "C:\Program Files\Autodesk\Vault for SharePoint 2010\Autodesk Vault for Sharepoint 2010.pdf"
After using that as a guide, was able to get the instance going.
Some things look very slick in the integration, can't wait to become comfortable with the solution. I think this was R&D $ well-spent.
Can this be done through the sandbox instead of installed directly on the server and can it use Kerberos contrained protocol/smartbadge x509 certificate authencation.
