Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Auto Numbering Schemes
5 REPLIES 5
scottmoyse
445 Views, 5 Replies
I assume Auto Numbering isn't supported via the Solid Body modelling 'Make Part' or 'Make components' commands? Does anyone know any different?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
5 REPLIES 5
Senthil_Kumar
in reply to: scottmoyse
Hi Scott,
Autonumbering is supported for Make Part and Make component commands. Please refer the attached video which shows the workflow. Is this you wanted?
Senthil Kumar
Development Manager,
Be sure to check out the Vault Help!
scottmoyse
in reply to: Senthil_Kumar
perfect thank you for clarifying it
Scott Moyse
acanfield
Will the autonumber work for tubes generated by Routed Systems?
It will populate the 'phantom assy & skeleton sketch (route)' but not the tubes!
Esky99!
Right click on the upper piping assembly and there is a prompt setting. Change that and the auto routing will work.
Esky99!
in reply to: acanfield
Change that and the auto numbering will work.
