Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Attaching a file to a Vault Objects
4 REPLIES 4
256 Views, 4 Replies
We're runing Collaboration 2010 with Inventor. Within the Collaboration client, there is an option to attach a file. When I try to attach a file, there is aprompt telling I don't have the correct permissions to complete this task.
Can someone tell me where I can change the permissions for this?
Joe
4 REPLIES 4
dickyshu
Hi Joe,
At first please make sure your role has the rights to attach a file, in Collaboration we have below roles can do this:
*Document Editor (Level 1)
*Document Editor (Level 2)
*Administrator
You can assign role to specific user from:
*Vault Collaboration Client
Tools->Administration, Security tab, Users
*ADMS 2010
And then you can modify the permission of that file or folder from Vault Collaboration main menu:
File->Properties, Security tab
Hope this helps,
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
Dicky,
Thank you for your help.
My users has those rights at the group level and at the user level.
It still doesn't work.
Joe
dickyshu
Could you please check the ACL of the file you want to attach something on?
You can view it via:
1> Select the file in Vault Explorer.
2> Main menu: File->Properties...
3> Security tab
Check that to see if you assign the correct rights to this file.
If your user was assigned appropriate permission, the file may also be locked from editing by state-based security.
Please check the status of the file. Is it in Work In Progress? or other status you may not be able to edit on.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
Dicky,
Yes, I found the problem. The file has to be in any other status, other then RELEASED.
Joe
