Can i add text box in general change order like "Detailed Description" ?,
because i need it, (without use properties in change order)
Tell me how to create new for this,
Thank you before
Hi sbmrnd01,
By default you cannot add any additional text boxes, you should consider using CO Properties if this is required.
You may however be able to write something in the API, I'd recommend logging that question in the customizations Discussion Group page:
http://forums.autodesk.com/t5/Autodesk-Vault-Customization/bd-p/301
