Another question for those who have gone through this already....
I have mapped several "Date" properties to my titleblocks in both Inventor and Autocad 2013. In Inventor the mapping for this property comes up as a date, and populates the titleblock correctly. In the Autocad mapping it comes up as "Text", and popultaes the titleblock with the date AND time (usually 12:00:00 AM), which is way too large for the field, and ... I don't want it! LOL
Is there something special I have to do in Vault, or in Autocad, to get JUST the date to show up?
The property in Vault is set up as a Date, so that when I edit properties, it pulls down the calandar for me to pull the date from. I don't want to just type in a date.
TIA!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by xavier_dumont1. Go to Solution.
I notice in the "Add properties" window, that system properties which are a date have several options including "Date Only".... can you do this with a UDP?
Chris Benner
Unfortunately, it's a bug... No way to change how this date is displayed in Autocad.
Does somebody from Autodesk care about that bug? I already ask to change this through Autodesk Feedback, through Autodesk Support but without success...
The only workaround is to set a string UDP in place of a date UDP in Vault but you loose functionality like searching for a range of date...
Anyone from Autodesk care to comment on the status of this? If it works in Inventor it should work in Autocad... IMHO.
Chris Benner
This has been logged and the development team is aware of the issue. No information is available on if or when it could be addressed.
