Hi, I'm planning to upgrade ADMS Server 2012 to ADMS Server 2014 without upgrading Inventor 2012 and Vault client 2012. Will this work?
I red that the new installation of ADMS Server 2014 will ''migrate'' the database. Does Inventor 2012 will still be able to open files from the migrated database?
While installing ADMS server 2014 I get this Error. Please tell me how to solve. Thanks
Checking ASP Status
Accessing a static file through the http protocol has passed. ASPX file failed to run at URL:http://localhost:80/TestASP/TestASPNet.aspx.The remote server returned an error: (500) Internal Server Error.
Failure
If you click on the failed pre-check in question, it should bring up suggestions for what could solve the problem.
What do those say?
-Dave
Hi Dave,
We have finally manage to do the installation of ADMS server 2014. But I want you to know some problem that we have gone throught. First, when we modify the credentials, the ''Install'' button of this screen does not refresh with the correct credentials and you get a credential error. You have to return to the previus page to have the credentials refresh and launch the installation. Second, we had to solve a ASPXnet error. We succed by running ASPXnet ApplicationPool in v4.0.
Thank for your help
Pier
