Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
ADMS Console 2010 Could Not Find the Data Management Services on 127.0.0.1
2 REPLIES 2
sean.r.egger
742 Views, 2 Replies
Our server ran out of disk space yesterday, so space was cleared out of the C:\ drive ~ 50 GB currently available. I restarted our server, but access to our server from the Vault 2010 client side yields the following error:
"Autodesk Vault 2010 could not find the Data Management Services on XX.XX.X.XX."
From the server side, ADMS console 2010 is running fine, but when Tools -> Administration is selected, the following error message shows up:
"Autodesk Management Server Console 2010 could not find the Data Management Services on 127.0.0.1."
When accessing http://127.0.0.1/autodeskdm services/securityservice.asmx, message shows:
"Could not load file or assembly "Connectivity.Platform' or one of its dependecies. There is not enough space on the disk. (exception from HRESULT: 0x80070070) - see attached
Is there a solution to this problem short of reinstalling ADMS?
Tags (2)
2 REPLIES 2
minkd
in reply to: sean.r.egger
Given that the ADMS-Console works until you go to Tools/Administration it would appear that SQL Server is up and running fine, but IIS may not be.  I recommend re-starting IIS.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
sean.r.egger
in reply to: minkd
Thanks!  Worked like a charm!
