Hello
Appeared probelm when migrating from professional 2012 until 2014.
2014-08-13 06:37:44 ==== Logging initiated: Core server version 18.2.2.0 ====
2014-08-13 06:37:44 Restoring Databases... 5/7
2014-08-13 06:38:09 *******************************************************************
Warning: Rolling back restore.
Exception: A transport-level error has occurred when sending the request to the server. (provider: TCP Provider, error: 0 - An existing connection was forcibly closed by the remote host.)
Data:
Windows Server 2012, SQL 2012 Standard Edition, ADMS 2012 Sp2
Store files on a remote resource - a virtual machine
SQL database - even on a remote resource
Any ideas?
greetings
The error indicates the that connection to the SQL Server was closed by the SQL Server. Thsi can happen if someone reboots or restarts the SQL Services.
For the SQL issue you'd have to look at the Event Logs on the SQL Server to see what is happening, Vault wouldnt cause this issue.
For your other issue, right click on the Vault and Enable it on the site.
I turned on the repository, and the file store, and I did the migration.
Question: Is the restoration and appears, the first error, the data is restored correctly?
When you run the Vault client everything works properly.
Status indicates the file store strange information: er 5
As to the log of the SQL it looks like this: er 6
Can you change the SQL side to this error does not it?
