Yesterday I spent about half the day making changes to an elaborate frame drawing. 7 sheets of section and detail views for the welders. Inventor 2013, Frame generator. I opened the file in the morning, in Vault it was set to WIP. Get revision from Vault.... and go to work. I finished the changes, saved the files, and checked the assembly back in to the Vault. Set the state to "review" on both the file and Item, and had the project manager look it over. This morning he asked for a few small text and balloon changes. So I set the status back to WIP, opened the file in Inventor and did a Get Revision. Now, the local files HAD been saved last night, before checking them back in. So, logically I should not see any difference between the local and vaulted copy. I made the changes he asked for, checked it back in and set it to Released so we could send it to the welding shop. When they reviewed the drawings,.... all of the changes I had made yesterday.... were gone. We're all stumped. We all saw the changes... IN the vault, last night.
This is not good for my confidence level.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
Looks like this one is on me after all. I did save and check in the drawing, but not the full assembly of the frame. When I checked the drawing back out, Vault decided to refresh the assembly, and I did not pay attention to what was happening. Vacation cannot come soon enough. At least it's true that changes always go faster the second time through.
Chris Benner
