Vault General Discussion
*Expert Elite*
karthur1
Message 1 of 2 (174 Views)
2013 Vault browser keeps losing the column headings
174 Views, 1 Replies
05-08-2012 05:28 PM
2012-05-08_1912.pngIn
Vault 2013, I keep having to reset the column headings (Customize View>Reset).  The first time it happened I marked it off as a glitch.  Second time I did a repair install on the 2013 client.  Third time, I ignored it.  This is the fourth time I have done the reset thingy.
 After I reset the browser columns, I customized it a little by adding a couple columns and taking out a few that I dont use.  This time I will export it so I can import it when it happens again.
Whats up with this?
Employee
yuhui.zhang
Message 2 of 2 (130 Views)
Re: 2013 Vault browser keeps losing the column headings
05-10-2012 09:56 PM in reply to: karthur1
Please check if remove current customized configure help -
Close Vault client, go to path "C:\Users\<OS username>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\Servers\<serverName>\Vaults\<vaultName>\Objects"
delete the xml files. restart Vault client and try again.
Fay Zhang
Software QA Engineer
Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
