In
Vault 2013, I keep having to reset the column headings (Customize View>Reset). The first time it happened I marked it off as a glitch. Second time I did a repair install on the 2013 client. Third time, I ignored it. This is the fourth time I have done the reset thingy.
After I reset the browser columns, I customized it a little by adding a couple columns and taking out a few that I dont use. This time I will export it so I can import it when it happens again.
Whats up with this?
Please check if remove current customized configure help -
Close Vault client, go to path "C:\Users\<OS username>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\Servers\<serverName>\Vaults\<vaultName>\Objects"
delete the xml files. restart Vault client and try again.
