Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
vault login with API
9 REPLIES 9
Message 1 of 10
lornemartin
2101 Views, 9 Replies
I am trying to run the C# VaultFileBrowser sample program in the vault 2012 SDK.  Everything compiles ok, but when I run it and try to log in, I always get an error saying 'Error: Logon Failed'.  I am using exactly the same login info as when I normally log into the Vault. Does anybody have any idea of what could be going on?.
  The line that throws the exception is this:
ServiceManager = new WebServiceManager(new UserPasswordCredentials(
                    loginInfo.ServerString, loginInfo.Vault, loginInfo.Username, loginInfo.Password));
 I have a working program that uses the older way of logging in:
public static void InitServices()
            secSrv.SecurityHeaderValue = new Autodesk.Connectivity.WebServices.SecuritySvc.SecurityHeader();
            secSrv.Url = "http://" + HOST + "/AutodeskDM/Services/SecurityService.asmx";
            secSrv.SignInReadOnly("lorne", "lorne", "Vault");
            docSrv.SecurityHeaderValue = new Autodesk.Connectivity.WebServices.DocumentSvc.SecurityHeader();
            docSrv.SecurityHeaderValue.UserId = secSrv.SecurityHeaderValue.UserId;
            docSrv.SecurityHeaderValue.Ticket = secSrv.SecurityHeaderValue.Ticket;
            docSrv.Url = "http://" + HOST + "/AutodeskDM/Services/DocumentService.asmx";
            propSvc.SecurityHeaderValue = new Autodesk.Connectivity.WebServices.PropertySvc.SecurityHeader();
            propSvc.SecurityHeaderValue.Ticket = secSrv.SecurityHeaderValue.Ticket;
            propSvc.SecurityHeaderValue.UserId = secSrv.SecurityHeaderValue.UserId;
            propSvc.Url = "http://" + HOST + "/AutodeskDM/Services/PropertyService.asmx";
  I notice that with this code I am signing in as read-only, could that be what is causing the login to fail in the sample program?
9 REPLIES 9
Message 2 of 10
Redmond.D
in reply to: lornemartin
Run in the debugger and verify all that the inputs to UserPasswordCredentials are correct.  What is the ServerString value?
I don't think this is a read-only issue.
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 3 of 10
lornemartin
Message 4 of 10
Redmond.D
That all looks good and the WebServiceManager should be able to handle a server on a different port.
The server you are connecting to, is it a Vault 2012 server?
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 5 of 10
lornemartin
in reply to: Redmond.D
Yes, it is a Vault 2012 server.
I'm not quite following, I do want to connect using the same port as when I 'normally' log in don't I?  The bottom screenshot on my previous post shows my normal log in values.
Message 6 of 10
Redmond.D
My port comment was referring to the fact that your server is not running on the default port 80.
Some other things to check.
- Which line of code is failing?  Is it the line that sets "ServiceManager" or the line that set "VaultExplorer"?
- Are you using the basic version of Vault?
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 7 of 10
lornemartin
It's failing on the ServiceManager line.  The output window shows this:
A first chance exception of type 'System.Configuration.ConfigurationErrorsException' occurred in Microsoft.Web.Services3.dll
A first chance exception of type 'System.Exception' occurred in Autodesk.Connectivity.WebServicesTools.dll
 We are using Vault Collaboration.
Message 8 of 10
Redmond.D
You are getting a configuration Exception from Microsoft.Web.Services3.  I think that's the problem.
Either the app.config file has been modified or Web Service Extensions (WSE 3) is not installed.  WSE 3 is part of the Vault client and server install.  See this article for more information.  That should get the WebServiceManager to log in property.
Note: The VaultExplorer line will fail if Vault Client is not installed.
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 9 of 10
lornemartin
I do have WSE installed and as far as I can tell from the article you referenced, it's setup properly, at least the config files look right. I don't have access to the server to do the test you describe. You mention that WSE is part of the vault install. I do remember installing it separately, so maybe something is not quite set up right.
  I also see that I didn't copy all of the lines from the output window before, maybe that would point to a possibly different problem?
'VaultFileBrowser.exe' (Managed (v2.0.50727)): Loaded 'C:\Windows\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll'
A first chance exception of type 'System.Security.SecurityException' occurred in mscorlib.dll
A first chance exception of type 'System.Configuration.ConfigurationErrorsException' occurred in System.Configuration.dll
Message 10 of 10
Redmond.D
Try running as an administrator to see if that clears up the security Exceptions.
Doug Redmond
Software Engineer
Autodesk, Inc.
