I'm new to Vault and plan to create a customized function to create Change Order. It works. after that, I use UpdateChangeOrderRoutingMembers to add routing to change order. then I got error message when I switch to tab Routing. Here is the error message:
The given key was not present in the dictionary.
I'm wondering if it related to the security setting I did. I setup security according to Folder.
Folder $CIBC only managed by user group "CIBC CAFM" and user Administrator.
user group "CIBC CAFM" only contain user lisav, Roles is "Document Editor (Level 1), Change Order Editor (Level 2)
user lisav does not have any roles.
I tried a couple of thing but nothing works.
1. change user group "CIBC CAFM" roles to "Document Editor (Level 1), Change Order Editor (Level 1)”
2. change lisav's role to “Change Order Editor (Level 2)”
Here is the code to get the User from userGroup (here userGroup = "CIBC CAFM")
public List<User> GetUserFromUserGroup(string userGroup) { IEnumerable<Group> groups = _adminSvc.GetAllGroups().Where(n => string.Compare(n.Name, userGroup, true) == 0); GroupInfo[] groupInfos = _adminSvc.GetGroupInfosByGroupIds(groups.Select(n => n.Id).ToArray()); List<User> ret = new List<User>(); foreach (var a in groupInfos) foreach (var b in a.Users) ret.Add(b); return ret; }
here is the code to get RoutingUserRoles from client ("CIBC CAFM")
public RoutingUserRoles[] GetMembers(string client) { List<User> users = GetUserFromUserGroup(client); RoutingUserRoles[] member = new RoutingUserRoles[users.Count]; for (int i = 0; i < users.Count; i++) { member[i] = new RoutingUserRoles(); member[i].UserId = users[i].Id; long[] arrayLong = new long[1]; arrayLong[0] = 2; // 2: Change Administrator member[i].RoleIdArray = arrayLong; } return member; }
Here is the code to add routing to change order:
RoutingMembAndRoles rmar = helper.coHelper.ChangeOrderService.UpdateChangeOrderRoutingMembers( newCo.Id, defaultRouting.Id, member, null);
Thank
Wes
Hi:
when I run the code this morning, It suddenly works. I do change some code, but I don't think anything affect it. If it happen again, I will see if I can provide more detail. now I have to close this case. Sorry to bother you for your time.
Thank you
Wes
