Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
inventor vault browser refresh / update? after changing lifecycle states.
2 REPLIES 2
2110 Views, 2 Replies
I use the attached code to change lifecycle states on files inside vault, based on the assembly bom open in inventor.
All works fine, but i manuel have to click the vault browser refresh button inside inventor to update the browser in inventor, is there anyway to do this via the API? Maybe this is a inventor customization question.
Please help!
Regards kent boettger
    Private Sub CheckLifeCycleStateOnFiles(ByVal strVaultFilePath1WithoutFileName As String, ByVal mVaultfilename As String, ByVal strLocalFilePathWithoutFileName As String, ByVal strLocalFilePathWithFileName As String, ByVal DocSrv As DocumentService, ByVal DocSrvExt As DocumentServiceExtensions)
        'Get hostname for FileCheckOut
        Dim strHostName As String
        strHostName = System.Net.Dns.GetHostName()
        'Set the VaultFileName
        Dim oVaultFileName As String = mVaultfilename
        'Set the VaultFileFolder
        Dim oVaultFileFolder As Folder = DocSrv.GetFolderByPath(strVaultFilePath1WithoutFileName)
        'Loop because fileID changes when changing LifeCycleState
        For i As Integer = 0 To 2
            Dim oVaultFiles As Autodesk.Connectivity.WebServices.File() = DocSrv.GetLatestFilesByFolderId(oVaultFileFolder.Id, False)
            For Each oVaultFile As Autodesk.Connectivity.WebServices.File In oVaultFiles
                If oVaultFile.Name = oVaultFileName Then
                    Try
                        'Get FileID
                        Dim ThisFileID As Long = oVaultFile.Id
                        'Get FolderID
                        Dim ThisFileFolderID As Long = oVaultFileFolder.Id
                        'Get file master ID
                        Dim ThisFileMasterID() As Long = New Long() {DocSrv.GetFileById(oVaultFile.Id).MasterId}
                        'Create array of LyfecycleStates
                        Dim ThisFileLifeCycleState() As Long = New Long() {24, 25, 26, 27, 28}
                        'Lifecycle Definitions
                        'Name : Monsun Basic Release Process = 6
                        'Lifecycle States
                        'Work in Progress = LifecyclestateID 24
                        'For Review = LifecyclestateID 25
                        'Released = LifecyclestateID 26
                        'Obsolete = LifecyclestateID 27
                        'Ready for deletion = LifecyclestateID 28
                        Dim ThisFileLifecycleStateName As String = DocSrv.GetFileById(ThisFileID).FileLfCyc.LfCycStateName
                        Dim ThisFileLifeCyclestateID As Long = DocSrv.GetFileById(ThisFileID).FileLfCyc.LfCycStateId
                        Dim ThisFileLifeCycledefinitionID As Long = DocSrv.GetFileById(ThisFileID).FileLfCyc.LfCycDefId
                        'MsgBox("Filnavn : " & oVaultFile.Name & " FileID : " & ThisFileID & " FileMasterID : " & ThisFileMasterID(0) & " StatusNavn : " & ThisFileLifecycleStateName & " Status : " & ThisFileLifeCyclestateID)
                        ' check if the file has status released
                        If ThisFileLifeCyclestateID = "26" Then
                            Try
                                'set the file to lifecycle state "for review" to prevent revision number change on checkout.
                                DocSrvExt.UpdateFileLifeCycleStates(New Long() {ThisFileMasterID(0)}, New Long() {ThisFileLifeCycleState(1)}, "Ax2009 Properties sync.")
                            Catch ex As Exception
                                MsgBox(ex.Message & " Error change from, Released to For review")
                            End Try
                        End If
                        'check if the file has status "For Review"
                        If ThisFileLifeCyclestateID = "25" Then
                            Try
                                'set the file to lifecycle state "Work in Progress"
                                DocSrvExt.UpdateFileLifeCycleStates(New Long() {ThisFileMasterID(0)}, New Long() {ThisFileLifeCycleState(0)}, "Ax2009 Properties sync.")
                                MsgBox(ex.Message & " Error change from, For review to Work in progress")
                            End Try
                        End If
                        'check if the file has status "Work in Progress"
                        If ThisFileLifeCyclestateID = "24" Then
                            Try
                                'check if the file is checked out if not check out the file
                                If oVaultFile.CheckedOut = False Then
                                    Dim fileData As Byte() = Nothing
                                    oVaultFile = DocSrv.CheckoutFile(ThisFileFolderID, ThisFileID, CheckoutFileOptions.Master, strHostName, strLocalFilePathWithFileName, "Ax2009 Properties sync.", False, False, fileData)
                                    Dim mfilepath As String = (strLocalFilePathWithoutFileName & oVaultFileName)
                                    SetFileReadAccess(oVaultFile, mfilepath)
                                End If
                                MsgBox(ex.Message & "Error checking out file from Work i progress")
                            End Try
                        End If
                        'check if the file has status "Obsolete"
                        If ThisFileLifeCyclestateID = "27" Then
                            MsgBox("The file " & strLocalFilePathWithFileName & " is set to, Obsolete - Replace the file with the new one")
                        End If
                        'check if the file has status "Ready for Deletion"
                        If ThisFileLifeCyclestateID = "28" Then
                            MsgBox("The file " & strLocalFilePathWithFileName & " is set to, ready for deletion")
                        End If
                        MsgBox(ex.Message & " Error in change lifecycle state")
                    End Try
                End If
            Next
        Next
    End Sub
    'Sets the read-only value of a file.
    Sub SetFileReadAccess(ByVal LocalVaultfile As Autodesk.Connectivity.WebServices.File, ByVal LocalVaultFilePath As String) ', ByVal SetReadOnly As Boolean'ByVal LocalPath As String,
        Try
            Dim info As System.IO.FileInfo = New FileInfo(LocalVaultFilePath)
            info.IsReadOnly = False
            info.CreationTime = LocalVaultfile.CreateDate
            MsgBox(ex.Message)
        End Try
    End Sub
2 REPLIES 2
wayne.brill
Hi Kbo,
Try using the VaultRefresh command. You can run a command from the Inventor API using the Execute function.
Here is a VBA example:
Public Sub sendVaultCommand()
ThisApplication.CommandManager.ControlDefinitions.Item("VaultRefresh").Execute
End Sub
You can get all commands that Inventor supports (including the commands added by the Vault AddIn) by using code similar to this. (it is from the Inventor help file)
Sub PrintCommandNames()
Dim oControlDefs As ControlDefinitions
Set oControlDefs = ThisApplication.CommandManager.ControlDefinitions
Dim oControlDef As ControlDefinition
Open "C:\temp\CommandNames.txt" For Output As #1
    Print #1, Tab(10); "Command Name"; Tab(75); "Description"; vbNewLine
For Each oControlDef In oControlDefs
        Print #1, oControlDef.InternalName;  Tab(55);   oControlDef.DescriptionText
Next
Close #1
End Sub
The Vault AddIns such as the Inventor AddIn do not have any customization support.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
in reply to: wayne.brill
Thank's
The "VaultRefresh" was what i was looking for.
