Where is the Category iproperty in vault customize feilds??/
Is ti hiding somewhere in the vault setting or ???
Am i missing somethin????? a muffin !!!
Are you talking about Vault Propertie Definitions? What do you mean by customize fields?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hey Chris,
How are you mate????
In Vault, Select an Assembly or Part then if you go to edit ( in menu Panel) and click Edit Properties, it will open Property Edit Window, Where you can select different Property feilds, from the list. to make do any changes.
In those feilds we got every other property Except Category.. We got Vault Basic installed on work satations and it is a single site Vault setup.
May be you can point out me in right direction if I miss something.
Cheers.
Could this help you?
cheers,
