I need to locate the vcet.config file through the API. I have found that this should be possible via Autodesk.Connectivity.Extensibility.Framework namespace. But what is the syntax to get the file and folder properties of the vcet.config file?
Thank you.
Solved by Redmond.D. Go to Solution.
What do you mean by "file and folder" properties?
If you are talking about attribues on the local file, such as the read only bit, then you can use System.IO.File. All you need is the full path.
You can get the paths through the Loader framework. There are a couple of approaches you can take. For example, you can scan through the possible Extensions. I believe that the Extension.Location property is the path to the .vcet.config file.
