is it possible to en-/disable commanditems in Vault Explorer. E.g. some of my commands only work when a file is not checked out.
Is it possible to add a sperator to a pulldown menu?
Thanks, Stephan
Hello Stephan,
You can enable and disable a custom command based on the type of entities selected and whether multiple selections are allowed, but you can't enable or disable them based on if a file is checked out or not. As a workaround, I would suggest having your command test if the selected file is checked out or not, and respond appropriately during the command execution.
Also, I don't believe it's possible to add a seperator to a pulldown menu.
Hi Daniel,
thanks for your answer. Probably this can be added to a future release of Vault. At least the seperator should be an easy task;-)
--Stephan
nothing changed in 2012 and 2013.
But you can vote for it at the vault idea exchange:
http://forums.autodesk.com/t5/Autodesk-Vault-Idea-Exchange/Enable-Disable-MenuItems/idi-p/3551916
--Stephan
