Hi
i have some little Problems to create the Vault.xml manualy
on The Line
<Association ChildId="_365269" Source="INVENTOR" RefId="1" NeedsResolution="true" Type="Dependency" />
i need to get the RefId
on Vault Wiki
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0170-Administ170/0302-Vault_Da0/0001-Extracti1
there also no good answer then on Inventor API there no RefiID!
how i can found the RefID with the Filename in the Inventor File
thx for Hionts or Tips
Mario
Solved by minkd. Go to Solution.
Unfortunately, you can't.
I think the best thing to do is leave it off for the import, and then use the "Update Files References" in Vault Explorer to correct the file assosiations afterwards.
-Dave
