Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Vault Data Transfer Utility / Vault.xml
2 REPLIES 2
1742 Views, 2 Replies
Hi
i have some little Problems to create the Vault.xml manualy
on The Line
<Association ChildId="_365269" Source="INVENTOR" RefId="1" NeedsResolution="true" Type="Dependency" />
i need to get the RefId
on Vault Wiki
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0170-Administ170/0302-Vault_Da0/0001-Extracti1
  • File Associations–For each iteration, file associations can be defined. The utility is able to care about file associations for Inventor using an attribute called RefId as an identifier. This identifier is used later on when documents are opened in Inventor. File attachments can be defined within the structure.
there also no good answer then on Inventor API there no RefiID!
how i can found the RefID with the Filename in the Inventor File
thx for Hionts or Tips
Mario
2 REPLIES 2
minkd
Unfortunately, you can't.
I think the best thing to do is leave it off for the import, and then use the "Update Files References" in Vault Explorer to correct the file assosiations afterwards.
-Dave
Dave Mink
Fusion Lifecycle
in reply to: minkd
Hi, do you have documentation for the xml syntax necessary for Vault Data Transfer Utility?
