I want to change the Inventor data card to allow a user to select the folder to place the file into at checkin.
as you can see in the attachment, all the folders are listed but not in the format of a tree or browser.
Is this possible to list out or browse to the vault folder?
thanks
Yes, it's possibile. There are 2 possibilities:
the folderPicker has been created a while ago to address exactly your request. It allows you to pick a folder from Vault, but it also keeps a history of the selected folders and allows you to set favorites. this way, you don't have to expand the folder tree every time. Additionally it's possibile to tewak the search logic, so that only folder of a certain type (for instance only projects) are shown. So, it's quite flexible. We made it free as we think this is something a lot of people need, so you can use the compiled version and also get the source code in case you like to go even further.
the second option i mentioned is quite cool, as WPF provides a lot of possibilities to create very cool looking controls. However, this is something that requires deep understanding of WPF technique, so i would suggest that you go with the folderPicker.
i hope this helps!!
ciao
marco
