Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Vault Data Control...Syntax help
4 REPLIES 4
steveh3
519 Views, 4 Replies
Trying to figure this whole Data Control thing out...So, far making headway. I have created a new tab in the item tab for our properties. Want to make the new tab the main tab rather than the General tab because there's a lot of properties that we don't use. So, I want to add the thumbnail, what's the syntax to make this happen? This is what I have....
<TextBox Text="{Binding Prop[thumbnail].image}" Grid.Column="3" TextWrap...
I can get other properties to come in, but can't get the thumbnail. I think my problem is with the red hi-light
Any help out there?
Thx,
Steve H.
Inventor---Vault Professional
4 REPLIES 4
Redmond.D
in reply to: steveh3
It looks like you are using XAML.  Is this a question about Vault Data Standard?
Offhand, I'm guessing that the problem is that you are trying to use a TextBox to show image data.  I suggest using an Image control.
Doug Redmond
Software Engineer
steveh3
in reply to: Redmond.D
Yes..changed it to an image and still having issue. Even moved it to another grid.
Here's the latest syntax I've tried...
<Image Source="{Binding Prop[Thumbnail].Value}" Stretch="None" Margin="400,0,190,530" />
steveh3
I just figured it out. In Visual Studio Express, I RMB'd on the image component having issues and chose  Order/Bring to Front. It now works.
steveh3
Now...is there a way to show the .idw image rather than the model image?
