I've used the DTU a number of times previously with great success, but now I'm experiencing this trying to EXPORT:
Logon Failure: Unknown user name or bad password
The ADMS administrator password is definitely correct in the command line, and the sa password is the default ***@26200 one.
Does the user currently logged into the server, does that Windows user account need to be given connect SQL or administrator permissions against the database in the AUTODESKVAULT instance?
I'm remotely connecting to a server using my domain logon, but I wouldn't have been given administrator rights within SQL as I wasn't with the company back when the Vault was installed.
Any help greatly appreciated!
Solved by Neil_Cross. Go to Solution.
I might/hopefully figure this out soon, but I'm exporting to a network share. If I change it to a local path, the DTU works. So it isn't related to SQL logins.
My share has everyone full control so I think I have that covered, but I'm not sure which account the DTU is using to authenticate against the share.
FYI anyone who comes across this in the future.
Problem was solved by creating a dummy account 'AutodeskVault' on the machine hosting the network share, and granting that account full control in the share. Thanks to Pim@CADAC for helping out with this one.
