I am in the progress of migrating from Vault 2011 to 2013 and need to update our custom applications accordingly.
In 2011 (WebServices) there was a method under DocumentService named GetAllPropertyDefinitions that would return an array of PropDef objects.
Now in 2013 that method is gone, at least not in the DocumentService.
I'm assuming there is something in PropertyService that will give me what I need but none of them look similar.
Ultimately what I'm trying to do is get a property(s) associated with a File, so if there is another way of doing this in 2013 I'd like to know about it.
I have done a bunch of searching on the ADN site and WikiHelp sites but there is little to no info on the 2013 Vault API...
Any help would be appreciated.
I was able to locate the Vault 2013 API Help file and found a line in the Changes section that answered my question.
eg:
PropDef [] defs = this.PropSvc.GetPropertyDefinitionsByEntityClassId("FILE");
For anyone looking for the Vault 2013 Help files they should be in the following location:
C:\Program Files (x86)\Autodesk\Autodesk Vault 2013 SDK\docs\VaultSDK.chm
