Hi all
I have been doing a lot of reading when it comes to Vault and licensing, but I have not found a solution to my problem.
The situation is as follows:
We have 18 designers and 25 Vault Pro licenses, this leaves 7 "floating" licenses for use around the plant.
The problem comes in when more than 7 users around the plant pull vault licenses, leaving designers without licenses and resulting in the loss of work in the design office.
Is there a way to track the use of the Vault licenses? I know the Vault log can be viewed but this takes too long to pin point who has licenses at any given time. Is there a program similar to Sam report, JTB FlexReport or OpenLM that can track the Vault license usage, or read from the Vaults log file and give an easy to understand output?
Is there a way to reserve Vault licenses for a set group of users? I already know that the NLM options file doesn't work, but is there something similar for Vault licensing? Or should Vault be setup in a different way to accomodate for this?
Any input will be greatly appreciated!
Carl,
I had to write my own program to read the log file and report the current users.
Thats what I'm starting to realise.
Did it take long to get something useable? We are thinking of taking that route.
The following works for most instances. It's something I had to throw together quickly because the licensing abuse was rampant.
HelpRichTextBox.Clear() Dim _completeList As New List(Of String) Dim I As Integer Dim _line As String = Nothing Dim _lineTot As Integer Dim _lineList As New List(Of String) Dim _loggedInList As New List(Of String) Dim _loggedOutList As New List(Of String) Dim _tempList As New List(Of String) Dim _userName As String = String.Empty Dim _userId As String = String.Empty ' Get the log text file. With OpenFileDialog1 .InitialDirectory = "C:\" .Filter = "txt files (*.txt)|*.txt|All files (*.*)|*.*" .FilterIndex = 2 .RestoreDirectory = True If .ShowDialog = Windows.Forms.DialogResult.OK Then Try ' Get the total number of lines Dim _lineTotal As Integer = GetNumberOfLines(.FileName) _lineTot = _lineTotal Dim _buffer As Array = File.ReadAllLines(.FileName) For I = 1 To _lineTotal - 1 _line = _buffer(I) If _line.Contains("Acquired license") Then _lineList.Add(_line) ElseIf _line.Contains("Releasing license") Then _lineList.Add(_line) ElseIf _line.Contains("Releasing inactive license") Then _lineList.Add(_line) End If Next I For I = 0 To _lineList.Count - 1 _userId = _lineList(I).Substring(_lineList(I).IndexOf("userId(")) If _lineList(I).Contains("username(") Then _userName = _lineList(I).Substring(_lineList(I).IndexOf("username(")) End If If _loggedInList.Contains(_userName) Then Continue For If _loggedOutList.Contains(_userName) Then Continue For ' Get a list the current user name. _tempList = _lineList.FindAll(Function(S As String) S.Contains(_userId)) ' Add current user to either the logged in or logged out list based upon the last item in the _tempList. If _tempList.Last.Contains("Releasing license") Or _tempList.Last.Contains("Releasing inactive license") Then _loggedOutList.Add(_userName) Else If _loggedInList.Contains(_userName) = False Then _loggedInList.Add(_userName) _completeList.Add(_tempList.Last & " {" & _tempList.Count & "}") End If End If Next I Catch ex As Exception MessageBox.Show("Cannot read file from disk. Original error: " & ex.Message) Finally HelpRichTextBox.AppendText("Total Licenses: " & _completeList.Count & vbCr & vbCr) For I = 0 To _completeList.Count - 1 HelpRichTextBox.AppendText(_completeList(I) & vbCr) Next UpdateStatusStrip("Finished auditing the liceneses.") End Try End If End With
FYI - that program doesn't take into account a server restart, after which there are no licenses out. The vlog entry written when the server is starting up indicates that licensing is initialized.
-Dave
