Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Remove tertiary links
3 REPLIES 3
g.heeley
699 Views, 3 Replies
Historically we have included views of parts on our assembly drawings. Now when we come to itemise the parts we are getting 100+ drawings referenced to the item as tertiary links. I want to write a little routine to do this but can't get the UpdateandCommitItem action to work. I am asusming its something to do with the last parameter (active inputs)
here's the function. I have used active input values of 0,1,2 and 4 to no avail
       /// <summary>
        /// Remove the unwanted tertiary linked files. These are extracted when a part is explicitly referenced in a Drawing
        /// </summary>
        /// <param name="itemId"></param>
        public void RemoveUnwantedTertiaryLinks(long itemId)
            Item selItem = m_itemSvc.GetItemsByIds(new long[] { itemId })[0];
            //Get the primary linked file
            ItemFileAssoc primaryFile = m_itemSvc.GetItemFileAssociationsByItemIds(new long[] { selItem.Id }, ItemFileLnkTypOpt.Primary)[0];
            //Get all the tertiary assocs for the item
            ItemFileAssoc[] itemFileAssocs = m_itemSvc.GetItemFileAssociationsByItemIds(new long[] { selItem.Id }, ItemFileLnkTypOpt.Tertiary);
            IEnumerable<long> fileIds = from fileassoc in itemFileAssocs select fileassoc.CldFileId;
            File[] files = m_docSvc.GetFilesByIds(fileIds.ToArray<long>());
            File drawingFile = null;
            //now match the drawing name to the primary fiule name and remove all the others
            foreach (File fle in files)
                //If the filename matches either the item number or the primary linked filename then keep it
                if (System.IO.Path.GetFileNameWithoutExtension(fle.Name).ToLower() == System.IO.Path.GetFileNameWithoutExtension(primaryFile.FileName).ToLower() || System.IO.Path.GetFileNameWithoutExtension(fle.Name).ToLower() == selItem.ItemNum.ToLower())
                    drawingFile = fle;
                    break;
                if (drawingFile != null) break;
            //now edit the item to update links
            Item editItem = m_itemSvc.EditItem(selItem.RevId);
            Item updateItem = m_itemSvc.UpdateAndCommitItem(editItem, primaryFile.CldFileId, false, null, null, null, null, null, new long[] { drawingFile.Id }, 1);
 Any one got any pointers?
Greg
Greg Heeley
CAD Administrator
temperzone Ltd
Inventor Pro, Vault Pro, ACADE
3 REPLIES 3
Redmond.D
in reply to: g.heeley
You are correct, it's related to the "active inputs" parameter.  Unfortunately, you have run into another documentation bug.  The CHM doesn't mention that 8 is the bit value for making the 'tertLinks' input active.
In the code you showed, 'secondary' is the only active field because you pass in 1.  If you want both 'secondary' and 'tertLinks' to be active, pass in 9.
Doug Redmond
Software Engineer
Maxim-CADman77
After you have deleted those links don't you have problem that they return on each Item update?
b.mccarthy
in reply to: Maxim-CADman77
How does one, without a coding background, insert & run this code?
Better yet, where is the secret, non-divulged setting that stops vault from linking every tertiary drawing to an item, when the item is assigned, or updated?
The current process of removal is to edit the item, RMB on the tertiary link, click Remove, accept the prompt, and click save (Vault will not allow a bulk removal). This is a mind-numbing operation when you have upwards of 100 unwanted links.
And to add insult to injury, all of the removed tertiary links will reappear when the item is updated.
I have heard that this is "By Design" but is this really the most efficient strategy, without allowing users the option to disable it?
TIA...  Hopefully...
