Yes, you can run searches thorugh the API. I don't think you will be able to run a search on exact patterns like DT-######.ipt. However, you can run something like "name contains DT" and "name contains ipt" to filter down the list of files. From there you can use code to verify the exact pattern.
I don't recommed VBA. It's much easier to use VB.NET instead. The Vault SDK has .NET libraries you can use and sample code.
Hi Alex,
The Vault Browser sample is a good example for working with files and folders. Previously I had updated the ItemEditor sample to get lifecycle state of Items. I attached that project. Here is the updates I added to the code. I believe the approach would be similar to get the lifecycle state of a file.
//wB added
string myPropString = myGetItemPropertyByPropertyNameOld(item, "State");
newRow[
"State Property"] = myPropString;
"Provider");
newRow[
"Provider Property"] = myPropString;
//wB end added
//wB added
String myGetItemPropertyByPropertyNameOld(Item mySuppliedItem, string myPropertyName)
string returnString = string.Empty;
try
PropDef[] itemProps = m_connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("ITEM");
// use LINQ to query the array
IEnumerable<PropDef> selection =
from propDef2 initemProps
wherepropDef2.DispName == myPropertyName
selectpropDef2;
if(selection.Count() == 0)
thrownewException("Property not found");
PropDefitemNamePropDef = selection.First();
long[] itemIdArray = newlong[] { mySuppliedItem.Id };
PropInst[] propValues = m_connection.WebServiceManager.PropertyService.GetProperties(
"ITEM", itemIdArray, newlong[] { itemNamePropDef.Id });
// LINQ will sort for you IEnumerable<PropInst> sortedValues =
from value inpropValues
orderbyvalue.Val
selectvalue;
PropInst[] values1 = sortedValues.ToArray();
PropInstmyPropInst = values1[0];
if (myPropInst.Val != null)
returnString = myPropInst.Val.ToString();
catch (Exceptionex) { }
finally{ }
returnreturnString;
//wB end added
Wayne
Hi Alex,
The example in this DevBlog post could also be helpful (it is VB.NET)
Wayne
Thanks for the reply/sample Wayne; much appreciated!
(Because I had nothing else to go on) I've taken the approach of borrowing the useful parts of the VaultBrowser SDK Sample so that I have an Excel AddIn which runs from a button in the 2010 Ribbonbar.
The code in the Ribbonbar button looks like this:
private void QueryVault_Click(object sender, RibbonControlEventArgs e) { if (Globals.ThisAddIn.Application.ActiveWorkbook.Name == "Project Tracker.xlsx") { Globals.ThisAddIn.InitializeSearchFromExcel(); } else { MessageBox.Show("This application will only work in the Project Tracker.xlsx file!"); return; } }
Coupled with the AddIn code:
using Autodesk.Connectivity.WebServices; using Autodesk.DataManagement.Client.Framework.Vault.Currency.Entities; using System; using System.Collections; using System.Collections.Generic; using System.Text.RegularExpressions; using System.Windows.Forms; using VaultBrowserSample; using Excel = Microsoft.Office.Interop.Excel; using Framework = Autodesk.DataManagement.Client.Framework; using Vault = Autodesk.DataManagement.Client.Framework.Vault; using VDF = Autodesk.DataManagement.Client.Framework; namespace QueryVault { public partial class ThisAddIn { #region Member Variables private Vault.Currency.Connections.Connection m_conn = null; //private Vault.Forms.Models.BrowseVaultNavigationModel m_model = null; public bool NoMatch = false; private List<Framework.Forms.Controls.GridLayout> m_availableLayouts = new List<Framework.Forms.Controls.GridLayout>(); //private List<ToolStripMenuItem> m_viewButtons = new List<ToolStripMenuItem>(); //private Func<Vault.Currency.Entities.IEntity, bool> m_filterCanDisplayEntity; private PropDef[] defs = null; public ListBoxFileItem selectedfile; #endregion private void ThisAddIn_Startup(object sender, System.EventArgs e) { } private void ThisAddIn_Shutdown(object sender, System.EventArgs e) { } #region VSTO generated code /// <summary> /// Required method for Designer support - do not modify /// the contents of this method with the code editor. /// </summary> private void InternalStartup() { this.Startup += new System.EventHandler(ThisAddIn_Startup); this.Shutdown += new System.EventHandler(ThisAddIn_Shutdown); } #endregion public void InitializeSearchFromExcel() { m_conn = Vault.Forms.Library.Login(null); if (m_conn != null) try { Excel.Workbook wb = Globals.ThisAddIn.Application.ActiveWorkbook; Excel._Worksheet ws = wb.ActiveSheet; if (!ws.Name.Contains("MODELLING")) { MessageBox.Show("Try switching to one the tabs labelled \"MODELLING\" and try again!"); return; } Excel.Range range = ws.UsedRange; //Excel.Range range1 = range.Columns[1]; //foreach (Excel.Range r in range1.Cells) //{ // string str = r.get_Value(Excel.XlRangeValueDataType.xlRangeValueDefault).ToString(); // //string str = (string)r.Value2(); // if (str != string.Empty) // MessageBox.Show("Drawing number= " + str); //} for (int i = 2; i < range.Rows.Count; i++) //need to start at row 2 accounting for headers and such-like. { Excel.Range r = range.Cells[i, 1]; string str = r.Value2 != null ? r.Value2.ToString() : ""; //string str = r.get_Value(Excel.XlRangeValueDataType.xlRangeValueDefault).ToString(); //debugging if (str != string.Empty) { //MessageBox.Show("Drawing number= " + str); Match match = Regex.Match(str, @"(.*\W)(\d{5,})(\S.*)|(.*\W)(\w\d{5})(\S.*)", RegexOptions.IgnoreCase); if (match.Success) { //search for the drawing number in the vault if (match.Groups[2].Captures.Count > 0) { Console.WriteLine("Drawing number matches the ###### or A##### pattern : " + match.Groups[2].ToString()); str = match.Groups[2].ToString(); } else if (match.Groups[5].Captures.Count > 0) { Console.WriteLine("Drawing number matches the ###### or A##### pattern : " + match.Groups[5].ToString()); str = match.Groups[5].ToString(); } Excel.Range rVaultedFileName = range.Cells[i, 3]; //hidden in Excel! Excel.Range rState = range.Cells[i, 4]; Excel.Range rRevision = range.Cells[i, 5]; Excel.Range rFileType = range.Cells[i, 6]; Excel.Range rVaulted = range.Cells[i, 7]; DoSearch( str, rVaultedFileName.Value2.ToString()); if (NoMatch != true && selectedfile != null) { if (selectedfile.File.EntityName.EndsWith(".iam")) { if (selectedfile.File.EntityName.StartsWith("AS-")) { rFileType.Value2 = "Assembly"; } else if (selectedfile.File.EntityName.StartsWith("DT-")) { rFileType.Value2 = "Detail Assembly"; } } else if(selectedfile.File.EntityName.EndsWith(".ipt")) { rFileType.Value2 = "Part"; } //add/update some information about the file in the Excel spreadsheet. //storing the filename that was selected means we don't need to prompt the user to choose again. rVaultedFileName.Value2 = selectedfile.File.EntityName.ToString(); rState.Value2 = selectedfile.File.LifecycleInfo.StateName; rRevision.Value2 = selectedfile.File.RevisionInfo.RevisionLabel; #region Is Vaulted //change the font to Wingdings rVaulted.Font.Name = "Wingdings"; //set the value to the right character to present a tick. rVaulted.Value2 = ((char)0xFC).ToString(); #endregion } else if(NoMatch == true) //need to mark the "VAULTED" Column with a Cross { #region Is NOT Vaulted rState.Value2 = "NA"; rRevision.Value2 = "NA"; //change the font to Wingdings rVaulted.Font.Name = "Wingdings"; //set the value to the right character to present a tick. rVaulted.Value2 = ((char)0xFB).ToString(); #endregion //reset the NoMatch bool NoMatch = false; } } } } } catch (Exception ex) { MessageBox.Show("The error was: " + ex.Message + "\n" + ex.StackTrace); throw; } //we need to be sure to release all our connections when the app closes Vault.Library.ConnectionManager.CloseAllConnections(); } private void DoSearch(string p, string VaultedFileName) { SrchCond searchCondition = new SrchCond(); searchCondition.PropDefId = 9; //filename bool searchedAlready = false; if (VaultedFileName != string.Empty) { searchedAlready = true; searchCondition.PropTyp = PropertySearchType.SingleProperty; searchCondition.SrchOper = 3; //equals searchCondition.SrchTxt = p; //our filename } else { searchCondition.PropTyp = PropertySearchType.SingleProperty; searchCondition.SrchOper = 1; //contains searchCondition.SrchTxt = p; //our drawing number } RunSearch(searchCondition,searchedAlready); } private void RunSearch(SrchCond searchCondition, bool searchedAlready) { SrchCond[] conditions = new SrchCond[1]; conditions[0] = searchCondition; string bookmark = string.Empty; SrchStatus status = null; //search for files List<File> fileList = new List<File>(); while (status == null || fileList.Count < status.TotalHits) { File[] files = m_conn.WebServiceManager.DocumentService.FindFilesBySearchConditions( conditions, null, null, true, true, ref bookmark, out status); if (files != null) fileList.AddRange(files); } if (fileList.Count > 0) { /*we have a match in Vault for our drawing number now we need to decide whether we completely automate the next step or allow the user to select the expected file. */ if (searchedAlready) { foreach (File file in fileList) { ListBoxFileItem fileItem = new ListBoxFileItem(new VDF.Vault.Currency.Entities.FileIteration(m_conn, file)); Globals.ThisAddIn.selectedfile = fileItem; //we should only be returning one file because we're searching for it directly! return; } } else { //create a form object to display found items string selectedfilename = string.Empty; FileSelectionForm fileForm = new FileSelectionForm(m_conn); //iterate through found files and display them in the search results list box foreach (File file in fileList) { ListBoxFileItem fileItem = new ListBoxFileItem(new VDF.Vault.Currency.Entities.FileIteration(m_conn, file)); fileForm.m_searchResultsListBox.Items.Add(fileItem); } //update the items count label fileForm.m_itemsCountLabel.Text = (fileList.Count > 0) ? fileList.Count + " Items" : "0 Items"; //display the form and wait for it to close using the ShowDialog() method. fileForm.ShowDialog(); } } } private void InitializePropertyDefs() { defs = m_conn.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId(VDF.Vault.Currency.Entities.EntityClassIds.Files); if (defs != null && defs.Length > 0) { Array.Sort(defs, new PropertyDefinitionSorter()); } } } #region "Search Condition Item Class" class SrchCondItem { public SrchCond SrchCond; public PropDef PropDef; public SrchCondItem(SrchCond srchCond, PropDef propDef) { this.SrchCond = srchCond; this.PropDef = propDef; } public override string ToString() { string conditionName = Condition.GetCondition(SrchCond.SrchOper).DisplayName; return String.Format("{0} {1} {2}", PropDef.DispName, conditionName, SrchCond.SrchTxt); } } #endregion #region PropertyDefinitionSorter Class /// <summary> /// Used for sorting collections of PropertyDefinition's. /// </summary> class PropertyDefinitionSorter : IComparer { /// <summary> /// Class (static) constructor that creates a static Comparer class instane used for sorting PropertyDefinition's. /// </summary> static PropertyDefinitionSorter() { m_comparer = new Comparer(Application.CurrentCulture); } private static Comparer m_comparer; public int Compare(object x, object y) { PropDef propDefX = x as PropDef; PropDef propDefY = y as PropDef; lock (m_comparer) { return m_comparer.Compare(propDefX.DispName, propDefY.DispName); } } } #endregion #region "ListBoxFileItem" /// <summary> /// A list box item which contains a File object /// </summary> public class ListBoxFileItem { private FileIteration file; public FileIteration File { get { return file; } } public ListBoxFileItem(FileIteration f) { file = f; } /// <summary> /// Determines the text displayed in the ListBox /// </summary> public override string ToString() { return this.file.EntityName; } } #endregion }
And finally the form that gets called when we need to search (if we haven't already):
using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using System.Text; using System.Windows.Forms; using VDF = Autodesk.DataManagement.Client.Framework; namespace QueryVault { public partial class FileSelectionForm : Form { private VDF.Vault.Currency.Connections.Connection m_connection; public string selectedfilename; public FileSelectionForm(VDF.Vault.Currency.Connections.Connection connection) { InitializeComponent(); m_connection = connection; } /// <summary> /// Takes the selected file in the list and passes the relevant information about it back to our Excel document. /// </summary> /// <param name="sender"></param> /// <param name="e"></param> private void button1_Click(object sender, EventArgs e) { ListBoxFileItem selectedfileitem = (ListBoxFileItem)m_searchResultsListBox.SelectedItem; if (selectedfileitem !=null) { Globals.ThisAddIn.selectedfile = selectedfileitem; this.Close(); } else { MessageBox.Show("You need to select a file!"); } } private void button2_Click(object sender, EventArgs e) { Globals.ThisAddIn.NoMatch = true; this.Close(); } private void m_openFileToolStripMenuItem2_Click(object sender, EventArgs e) { OpenFile(); } private void OpenFile() { if (m_searchResultsListBox.SelectedItem != null) { ListBoxFileItem fileItem = (ListBoxFileItem)m_searchResultsListBox.SelectedItem; OpenFileCommand.Execute(fileItem.File, m_connection); } } private void m_searchResultsListBox_MouseDoubleClick(object sender, MouseEventArgs e) { OpenFile(); } } }
I also copied across the "Condition, OpenFileCommand" Classes from the VaultBrowser sample but I don't need to post them here since they're available in the SDK.
Overall I think the above is working pretty well, but (and I was laid awake thinking about this last night) I've realised that there's a whole other set of information I can potentially pull out of the Vault that will help us to understand the effort required to finish a project of this kind.
Things like:
Outside of the Vault (and probably the scope of this thread) I plan to implement the following (based on an article I read yesterday regarding Agile Projects):
The accumulative score from these metrics would initially give us an idea of what effort is required for the baseline dataset provided by the survey team - then as the project progresses we would begin to see a pattern emerge which would show us whether the figure we had quoted was somewhere near accurate and enable to adjust the effort applied to each project.
TL;DR: The VaultBrowser source did what was needed (with a few tweaks!).
